x2 base5- f2 hata
Halil45
Kayıt: 04 Tem 2020, 18:07
x2 base5- f2 hata
Mesaj gönderen Halil45 » 04 Tem 2024, 10:07
merhaba x2 base 5 -f2 panele program attığım esnada aşağıdaki gibi hata alıyorum
09:07:15 Success Sending command : Start communication with 169.254.108.130
09:07:15 Verbose Received response Success for startcommunicationserver from: 169.254.108.130
09:07:16 Verbose Awaiting response for DeleteFiles from 169.254.108.130.
09:07:18 Verbose Warning: Target responded with - Error deleting \flashdrive\project\ToolsCF.DLL (System.IO.IOException: The process can not access the file '\flashdrive\project\ToolsCF.DLL' because it is being used by another process.
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.File.Delete(String path)
at CommunicationServer.Protocols.Command.DeleteFiles(XmlElement directoryElement, String[] files)
at CommunicationServer.Protocols.Command.DeleteFiles()
at CommunicationServer.Protocols.Command.ProcessCommand()
at CommunicationServer.Protocols.InformationDocument.Receive(BinaryReader reader)
at CommunicationServer.Protocols.InformationDocument.CommunicationServer.Protocols.smile.ITransferObject.Receive(BinaryReader reader)
at CommunicationServer.Protocols.MessageReceiverBase.ReceiveMessage(Stream networkStream)
at CommunicationServerLib.SocketServer.Execute(Socket clientSocket)
at CommunicationServerLib.SocketServer.<>c__DisplayClass1.<ConnectionRequest>b__0()
09:07:18 Success Sending command : Stop communication with 169.254.108.130
09:07:19 Verbose Received response Success for stopcommunicationserver from: 169.254.108.130
09:07:19 Verbose No project exectuable provided. Attempting to start existing project on panel.
09:07:19 Success Sending command : Start project on 169.254.108.130
09:07:19 Verbose Received response Acknowledge for startproject;project= from: 169.254.108.130
09:07:19 Verbose Received response Success for startproject;project= from: 169.254.108.130
09:07:19 Exception Failed while deleting old files on panel. Message: Error deleting \flashdrive\project\ToolsCF.DLL (System.IO.IOException: The process can not access the file '\flashdrive\project\ToolsCF.DLL' because it is being used by another process.
09:07:19 Failure Failed to download the project.
Re: x2 base5- f2 hata
Mesaj gönderen Teknik2 » 08 Tem 2024, 09:27
Yükleme işlemi hiç ilerliyor mu? Eğer ilerliyorsa % kaçta kalıyor ?
Aldığınız hatanın ekran görüntüsünü paylaşır mıısınız. Detayları açmadan.
